Daft Maxle Question
[Closed] Daft Maxle Question
[#1052285]
With the wheel off the bike, do you put the Maxle back in the hub or the forks?
Posted : 18/11/2009 5:32 pm
I put mine in the forks.
Are they meant slide right in or be a bit of a faff to get in and out? I've never used one before
Posted : 18/11/2009 5:36 pm
 nbt
I put mine in the forks. no faff at all - I find the maxle the easiest of all the various systems I've seen and used for attaching wheels to bikes
Posted : 18/11/2009 5:49 pm
+1 for nbt.
Ian
Posted : 18/11/2009 5:53 pm
Yes, put it back in the frame/forks or you'll only realise you've left it at home when you get the bike out of the car and try attatching your wheel.
Posted : 18/11/2009 5:56 pm
Yeah, put it back in the forks. Or you'll end up driving back to the trail head in your dressing gown and slippers at midnight only to get stopped at a police checkpoint and have to explain in broken Spanish why you are half naked! 😳
If it's a faff to get in and out then you'll probably need to give it a wee service. It's simple, take apart, clean and grease.
Posted : 18/11/2009 6:06 pm
a bit of copper grease in the threads of the fork and lightly smeared the length of the axle works well. i like mine done up on the snug side for peace of minds sake and often find that backing the end nut off a turn or so helps the axle get through the hub.
Posted : 18/11/2009 6:31 pm
I put it in the forks as that way I can thread it in, no chance of it falling out and being left on the garage floor.
Posted : 19/11/2009 1:53 am
I don't bother sticking it back in the forks but I guess if you drop it on the ground after taking it out it might be a useful memory aid, personally I shove my maxle in the boot of the car before even taking the wheel out.
Posted : 19/11/2009 10:33 am
has seemed to help, cheers
Posted : 19/11/2009 10:39 am
