Can anyone recommend some good ones ? Lycra shorts to go under baggies, no padding - don't like it the summer... gets too hot.
fanks,
Kev
If they're not padded they're not cycling shorts...
You could try a running shop
I always wear Endura coolmax cotton knickers.
They have padding but it does its job in the heat of summer without getting nasty.
Stoner, like these ones...
http://www.tredz.co.uk/.Endura-CoolMax-Boxer-2009-cycling-under-shorts_15217.htm
Kev
How on earth does the padding get hot!?
As above, if they're not padded, they're not cycling shorts!
You could try some tri shorts (as in triathlon), they're much less padded than cycling shorts. Those boxer type ones just hold onto all the sweat and are generally unpleasant!
[i]How on earth does the padding get hot!?[/i]
erm... me gets too hot. I find the padding prevents airflow to the all important parts of the body which we like to look after. It's caused me problems in the past, skin needs air to breathe. I don't dawdle around on a bike and sweat loads in this heat.
Kev
theyre the ones.
I lived in 2x pairs of them for 2 months cycling across Europe in early summer a few years ago. No arse ache, chaffing or anything. Ive never needed to use creams either.
theyve changed the design slightly I noticed when I finally retired my old set (must have done 2,000 miles each!). Now rather than just a fake chamois gusset pad, there is a kind of anti-bac thin towelling piece as well at the front.
All stick works just as well, and is still comfortable.
When I occasionally jump on my pomp to ride to the pub in normal boxers I really feel the seams and they are very uncomfortable. You forget just how much comfrot you get from a properly designed and cut short.
cheers, I'll buy a pair and see how they go.
Kev
I wear these for adventure racing when you don't want a pad because you'll be running and cycling, fantastic in hot weather
[url= http://www.wiggle.co.uk/p/run/8/Helly_Hansen_Stripe_Boxer/5360038628/ ]Helly Hansen Boxers[/url]
I have a pair of these too, again good under a pair of shorts
[url= http://www.wiggle.co.uk/p/run/8/Ronhill_Infinite_Short/5360041161/ ]Ron Hill Inifinty Shorts[/url]
Over a 2-3 hour ride I don't miss the pad at all
cotton liners like above are way cooler than lycra
although lycra is better in a downpour.
helly boxers win in the heat and are way cooler than cotton
thanks Nick, I've just bought a pair of those too !
Kev
