Bars, seatposts - anything to worry about?
e.g. is a facemask a good idea to avoid breathing in any particles?
Will any sharp saw blade do it?
Any particular technique required?
Posted : 22/02/2009 1:04 am
Wear a mask, keep the blade & component damp. Use a fine tooth count (high tpi) blade, measure 4 times, cut once 😉 Oh, and wear gloves.
Posted : 22/02/2009 3:27 am
Wrap tape around the area you are going to cut. Then mark up & cut through it. Mask is not optional.
Detailed instructions with pics on the Easton website
Posted : 22/02/2009 8:43 am
careful, the nanotubes will eat your brain!!
Posted : 22/02/2009 10:35 am
as everyone above has said, nice fine blade (high tpi), wear a mask, mark up using masking tape and you'll be fine.
Posted : 22/02/2009 11:02 am
