The bearings on my Canfield are shot. Theres four of them, and they are custom made with extended inner races.
Canfield have quoted $40 per bearing- which I think is absurd!
Anyone know if its viable to get this sort of thing made up?
What size are they?
"custom double row 20mm bearing with extended inner race (both sides)"
Thats all I know, but if there is somewhere that can make them up I will remove them and check..
Custom my arse,
Take them to a bearing supplier and they will sort you out, Bearing come in pretty much any size.
You will be talking hundrededs of pounds for a limited run custom made deep groove radial ball bearing.
Who says they are custom made?
Take them out measure the outside diameter, inside diameter and the width (of the outer raceway) probably a case of get an off the shelf bearing and use washers either side of the inner raceway to get the "custom width".
What happened to kaesae? Not seen him about in a while, did he get banned?
