Crud Road Racer MKI...
[Closed] Crud Road Racer MKII quick sizing question
I know these will fit 700x25 tyres but will they work ok with 120mm hib spacing at the back? I'm guessing yes but any input would be good. Thanks.
Posted : 16/08/2011 9:28 am
Really, no-one?
Posted : 18/08/2011 7:54 am
Hi Cupra
The key to fitting the Roadracers is this....can you get a 4mm allen key between the top of the tyre and the forks-brake bridge-brakes? If you can, then the Roadracers will fit. Doesn't matter what tyre size, it's the clearance that is important
Mr CRUD
Posted : 20/08/2011 7:27 am
