Crown race stuck on...
[Closed] Crown race stuck on carbon steerer, any tips.
[#9809122]
Been on there since new so at least 10 months, currently soaking with gt85. Very small gap all way round can just get electrical screwdriver in but its not budging. No larger gaps to get proper whacker in. Any tips?
Posted : 31/01/2018 7:23 pm
de tuned chisel or
spread the load
Posted : 31/01/2018 7:26 pm
Proper crown race remover
Posted : 31/01/2018 7:37 pm
^^^^ this
Posted : 31/01/2018 7:38 pm
You can borrow mine if your close😉
Or LBS
Posted : 31/01/2018 7:39 pm
Apply some heat to it. Boiling water ought to do it. That should expand the "crown race" enough to loosen it off. I use that technique when fitting it too. Makes it much easier to slip it on.
I also cut my "crown races" to remove this problem permanently.
Posted : 31/01/2018 7:59 pm
You can use a blade like on a leatherman (or one of your best kitchen knives!) go round the race with the sharp edge tapping it in with a small hammer, that'll get it moving, then hide the knife in the bottom of the cutlery drawer.
Posted : 31/01/2018 8:52 pm
I tried the leather an approach before but gave up.
went to my local garage and used their bearing puller thing, did the job nicely.
Posted : 31/01/2018 8:59 pm
A knife edge puller is the tool for the job.
Posted : 31/01/2018 9:11 pm
I got one off by hammering a Stanley blade into the gap. That was a steel steerer though.
Posted : 31/01/2018 9:14 pm
Use a proper race remover as it'll be even pressure. I've got the Icetoolz one, I would link it but thanks to the poxy forum at the moment there are no link buttons I can use....around £25 anyway.
Posted : 31/01/2018 10:26 pm
