Crown race removal?
[Closed] Crown race removal?
 Joe
[#5044791]
Anyone used one of these tools: http://www.amazon.co.uk/Ice-Toolz-Crown-Race-Remover/dp/B0058D8GGO/ref=pd_sim_sbs_sg_2
I used to use screw drivers and tappy tappy method, but my last couple of races are very very tight.
Posted : 08/04/2013 12:53 pm
Warm it with hair drier / heat gun.
Posted : 08/04/2013 12:57 pm
I used a chisel. Wouldn't necessarily recommend you do the same...
Danny B
Not used those but never had a problem with the grease and screwdriver method.
or boiling water
Posted : 08/04/2013 1:25 pm
I have one of those removers. be careful with it and it works a treat. gives a nice area to whack with a mallet.
Posted : 08/04/2013 1:28 pm
I use an old table knife. Just hold the blade where the race rests on the crown and give it a few shart taps with a hammer. Usually gets it moving.
Posted : 08/04/2013 1:32 pm
screwdriver method works for me...
Posted : 08/04/2013 1:39 pm
It's a great tool,simple and effective and if you need to regularly remove the race then I think it is well worth having. Lot's of other methods work if you only need to do the odd 1 and don't want to spend £20.
Posted : 08/04/2013 1:41 pm
I used the chisel/tappy method but worked a ring of paint off the crown of my last fork 😯
Cut a slot in your crown races and it's probably worth using the right tool, then sell it once your races are all split.
Hacksaw to split with a file to finish works fine and they're easy to remove from then on. Many brands sell them pre-split (Hope etc).
Posted : 08/04/2013 1:50 pm
And I thought £20 was a bit steep.
Posted : 08/04/2013 2:27 pm
Yep - used one after years of tapping off with screw drivers etc. Its a nice piece of kit - well made - effective - & will last forever...
Posted : 08/04/2013 2:37 pm
