I have a 1.5" headtube and a tapered fork. The headset is a reducer headset but the bearings are for 1.5". As far as I can see all I need to fit the forks is a 1.5" crown race. Anyone help?
Ta
Monday morning crew?
More info required. What headset? What frame ?If it's a reducer headset it won't fit the lower part of the fork as that part fits a 1.5 headset. The upper headset needs to be a reducer if your frame has a 1.5 non tapered head tube. Most crown races are headset specific.
Ps I have an fsa 1.5 headset and crown race that you could use on the lowers. Removed from new frame with new star nut and top cap £30
The headset is an FSA Big Pig R (R for reducer). My headtube is not tapered i.e. it is 1.5" at the top and the bottom. I bought the headset thinking I would but a normal 1.8" steer, but then got a good bargain on a tapered steerer fork. The upper headset is a reducer. The Fsa BIg Pig (non reducer) does have a 1.5" crown race so I assume that is all I need - wherever I may get one!
Is it a race for the FSA loose (caged) bearings rather than sealed cartridge bearings?
Yes it's the same as yours but not the reducer.
OK, if I can't get just the crown race you could be on - but my whole headset only cost me £32 anyway, could you come a bit lower? Would you sell just the crown race?
Will let you have it without the star nut as I'd like it as a spare and it's no use to you any way, for £28 then. It will cost £4 to post. You need more than the crown race as your lower cup is a reducer is it not. You will need the 1.5 lower cup no mater what.
The way the lower cup acts as a reducer is by virtue of the crown race. The race is for 1.5 " bearings, but with a hole for only 1.8" steerer. The cup is a full 1.5" cup.
I'll see if I can get the crown race on its own, but keep you in mind if not. Ta
Ah I see. Ok, no worries. You can have the race for £28 with a free headset then 🙂
lol
Found the race for £5. Thanks but no thanks 🙂
Dam. eBay it is then.
Hope it doesn't fit 😆
