Croozer kid 2 rain ...
[Closed] Croozer kid 2 rain cover
Any Dads bought the additional rain cover for their croozer trailer?
I'm using ours for the school / nursery run atm and leaving it sitting out all day, so more coverage sounds like a good idea.
However, pictures of the rain cover look pretty un-inspiring - seems to be just for the top and be a second layer to the existing clear plastic cover? Doesn't seem like it would make much diff?
Posted : 14/01/2013 10:45 am
yup i can confirm that it only covers the top section and a bit of the back and front, bascially leaves the sides exposed
I have exactly the same dilema as you and tend to bring it back home instead, ive got a plastic bike cover thingy ill try that and see if it fits!
Posted : 14/01/2013 10:55 am
I never bothered with it. Leave it outside playgroup once a week for a few hours, just with the built in rain cover, and it seems fine. Have also ridden in torrential rain, and the built in cover was fine until the flood-water came up to above the bottom of the trailer!
If you want to cover it when sitting out every day though, you probably want something similar to a lawnmower cover, but wider. Or some kind of tarpaulin affair.
I make sure it is kept in the warm and dry when not being used in the evenings, so at least it should get a chance to dry off after getting wet in the day.
Posted : 14/01/2013 11:19 am
Thks. I can throw a light tarp over it easily enough so might do that.
Posted : 14/01/2013 11:27 am
