Crooner trailer hit...
[Closed] Crooner trailer hitch attachments - thru axle
[#6734317]
Anyone know where I can get a croozer hitch that attaches to a thru axle (instead of QR). I have been looking at the Robert axle project in the USA however were talking about 80 squid delivered. Any cheaper UK options out there?
Posted : 29/12/2014 10:56 am
worked ok with mine but it is a pita to get on and off with my maxle
im sure someone linked to a cheaper option, maybe for a turbo trainer addaptor or soemthing?
Posted : 29/12/2014 11:02 am
Worth a shot. Did you just drill a larger hole in the hitch? If so does the maxle get enough thread purchase as the hitch would leave it proud?
Posted : 29/12/2014 11:06 am
yeah it still worked fine, leaves a couple of mm short at the other end
the problem was screwing in the maxle as my dropouts are quite chunky
the hitch still works fine on a normal QR so nothing to loose
Posted : 29/12/2014 11:09 am
Brilliant thanks Kimbers
Posted : 29/12/2014 11:12 am
Same here, just drilled mine out, works a treat! My maxle was on the limit if the thread so I got a solid bolt in for trailer duty and leave the 10mn hex key in the trailer.
Posted : 29/12/2014 8:13 pm
