Cranks and BB help ...
[Closed] Cranks and BB help sought
I'm stripping an old bike at the moment before it goes off to be powder coated...and I'm struggling with the cranks and BB.
All of my current bikes use hollowtech / external BB's but this one uses an internal BB.
I've removed a bolt that I assume is holding the crank arms onto the BB axle ...it's a square axle. There doesn't appear to be anything else holding the crank arms on, but I can't get them to move at all.
They might have corroded on, but before I start tackling that problem with penetrating fluid and some large hammers, I thought I'd check if I should be doing anything else.
Turning to the BB, there's a thin metal ring up against the frame - that unscrews easily...and assuming I can get the crank arms off, how will I get the BB out? Any special tools needed?
I have a few photos I can send if anyone would like to see them.
Thanks, smurf
Posted : 01/09/2014 9:33 am
Sounds like you need a crank extractor tool to get the cranks off and a bb removal tool to get the bb out.
Posted : 01/09/2014 9:39 am
Simon is correct, you'll need a crank remover tool:
http://www.wiggle.co.uk/bbb-btl-14-powerpull-crank-puller-tool/
This pushes the crank away from the square taper spline.
To get the BB off you'll need a different remover from your hollowtech tool:
http://www.wiggle.co.uk/lifeline-performance-cartridge-bottom-bracket-remover/
That works on most shimano BB's but check first.
Posted : 01/09/2014 9:46 am
this thread makes me feel old.
something like this to get the crank off ...
http://www.wiggle.co.uk/pedros-universal-crank-remover-with-handle/
And this to get the BB out ... be warned there are several spline
patterns !!
http://www.wiggle.co.uk/shimano-bottom-bracket-removal-tool/
Posted : 01/09/2014 9:47 am
Thanks all - I'll check out the tools and order something this evening.
Posted : 01/09/2014 12:12 pm
Quick update...the BBB crank puller from wiggle worked a treat. I also got a BBB BB tool and that worked a treat as well.
One side was a pig to remove but the other came off pretty easily.
Thanks for your advice guys
Posted : 22/09/2014 7:06 am
