My technical knowledge of parts interchangeability is next to none,
I would like to put shorter cranks on the wife’s bike it’s 2x10 Shimano deore XT with FC-622/625/627 175mm Cranks
Can anybody tell me if there are any 165s which would fit?
Posted : 02/07/2019 4:37 pm
Pretty much any standard Shimano crankset will do the trick.
https://www.chainreactioncycles.com/shimano-xt-m8000-double-11-speed-chainset/rp-prod135837
11speed rings will work with a 10speed drivetrain, or if the bolt circle diameters are the same, you can transfer your existing rings over.
Posted : 02/07/2019 4:47 pm
Big help thanks
Posted : 02/07/2019 4:48 pm
Its only XT,XTR,SLX,Zee, and Saint in 165mm MTB shimano I believe
Sram do some too
Posted : 02/07/2019 5:21 pm
