Crank options? 73mm...
[Closed] Crank options? 73mm threaded BB, boost chainline
As per the title, liked the look of Hope spiderless but with BB and chain ring costing around £300 all in, I'm looking at the options.
Running SRAM 11sp, so think I'm right in sayng that Eagle 12 rings would also work? So maybe DUB, although I'm not too sure what that even means
Posted : 13/12/2018 5:29 pm
You may not need Boost chainline. It'll depend on chain/tyre clearance and chainring/chainstay clearance. Find out if anyone else has the same frame/chainring requirements before you commit to a spend.
Posted : 13/12/2018 5:31 pm
My current cranks are 24mm from a PF30 system so pretty sure I need new anyway
Posted : 13/12/2018 5:40 pm
Descendent carbon DUB would be my first choice crank for sure. Light (enough), strong, excellent BB.
Posted : 13/12/2018 5:41 pm
FSA's modular cranks will let you fit to pretty much anything. Boost or non boost, threaded or PF.
Afterburner for 24 or 30mm pricepoint,
Grid for 24mm strength,
Gradient for 30mm strength,
SL-k/K-force for 30mm carbon lightness.
Posted : 13/12/2018 5:46 pm
