Does anyone (tall order i know) know the difference in weight of an SLX crankset (arms) and Xt crank arms?
try weightweenies
[url= http://weightweenies.starbike.com/listings.php ]http://weightweenies.starbike.com/listings.php[/url]
So that's the difference that paint makes basically. Are the chain rings any different or are they actually identical?
I do think there's more in it when rings are included, but basically, SLX is so good that it almost negates XT.
Chainrings are different- or were at least, when I got mine.
XTR's the same- the arms are a little lighter but most of the weight difference is in the other components.
As above, it's not very much. I've weighed both Mine (SLX and XT) both with just granny and middle rings as supplied from the factory (outer rings both removed) and the diff was about 50gms if irc. So, I presume 60gms ish dif for 3 chain rings. I certainly remember thinking that I would default to SLX in future. Not sure about XTR, beyond my price bracket.
Bugger, now I can't justify the xt option over slx when I go 2x10. That's almost a shame!
The weight is mostly in the rings & ancillaries.
XTR's are ~500g bare.
I've old XT and XTR chainsets, there was 100g difference with Shimano rings, but only 50g difference once they'd both got Middleburn rings on.
SLX supplied as twin and bash have steel pedal inserts so a bit heavier again - about 60g more than XT. The SLX supplied bashguard is very heavy too.
SLX 9spd triple complete is 889g claimed
XT 9spd triple complete is 853g claimed
So 36g difference (and usually around £36 sort of figure difference)
Bottom bracket is the same between them
IIRC
SLX inner chainring is steel
XT inner chainring is aluminium
SLX middle chainring is steel teeth/'composite' ring
XT middle chainring is steel teeth/'carbon'? ring
SLX outer is aluminium (as is XT) but SLX appears much chunkier
I always suspected there would be little between the arms. 6grams seems about right
[SLX double bash is ~1000g complete, same BB, but as above steel inserts, I seem to think its steel axle? has all steel rings (incl. 104BCD 36T) and as above (104BCD 36T) bashring not light]
Aren't all the Shimano axles steel? But, the axle on the SLX double is supposed to be a bit thicker/stronger. And the 36T chainring on the SLX double is aluminium. I wish it was steel as it would last a bit longer, but it isn't.
