Crack or not?
[Closed] Crack or not?
[#3037614]
My Planet X has never made a sound, now it creaks like mad. And I've noticed what looks like cracks where the chainstays meet the bottom bracket shell. And a odd white line 13" long down the downtube. You can feel both if you run a finger over them.
Is this just likely to be cracks in the lacquer?
Stripped, lubed and reassembled the chainset and bottom bracket, just in case.
Posted : 10/08/2011 10:18 pm
sounds like cracks.
Posted : 10/08/2011 10:19 pm
The creaking could be the front mech cable rubbing where it goes through the bb shell/seattube.
I put some plastic tube over mine and it stopped it creaking
Posted : 10/08/2011 10:20 pm
frame or coating?
Pics?
Seatpost as well? Or is it only when out of the saddle?
Bar/Stem interface is also well worth a look.
Posted : 10/08/2011 10:21 pm
bit of touch up paint and shove it on ebay
Posted : 10/08/2011 10:22 pm
Hmmm
Are there folk that can tell? it's only been raced two seasons and I used my crosser over winter.
Posted : 10/08/2011 10:25 pm
Yep, any good LBS will be able to properly diagnose the issue. Where are you based?
 nonk
check your hanger that can creak like a bastard. take it of run an oily rag over it bit of grease on the bolt etc.
Posted : 10/08/2011 10:26 pm
Not the bars/stem
does it out of the saddle.
Doesn't do it when locked into the Turbos.
It's that distinctive cracking sound you hear when you free a bolt or loosen a seatpost.
Posted : 10/08/2011 10:28 pm
Front mech cable???? I thought it was quite a known issue with PX frames!
Posted : 10/08/2011 10:29 pm
 nonk
check hanger and the QR cam give it some lube.
Posted : 10/08/2011 10:46 pm
You an always do a 10 foot drop or two and that should sort it out for you
Posted : 10/08/2011 11:22 pm
