Looking for some advice here, its "Needless upgrade" time!
Built up a transition covert about 9 months ago, new frame and bits I had from various other bikes. The wheel set came off a 06 Specialized Enduro - DT E540 on Specialized hubs, and are shod with 2.35 High rollers running tubes. Bit on the heavy side.
I'm looking at an a reasonably priced tubeless upgrade set of wheels.Are there any major weight savings to be had? Any recommendations on what to be looking for?
Flows with the same tyres run tubeless should save a nice whack.
Not sure how heavy your current wheels are, but what about Hope Hoops - Flow on ProII Evo? Not too porky, really solid and not too expensive either. I've been really pleased with mine so far.
Got Hope Hoops (Flows) on my covert
hope hoops flows for my covert too.
If those wheels are anything like the ones that came of my missus' pitch, you'll save a lot of weight!
Dave
I was thinking flow on hope hubs, possibly with 2,2 rubber queens, or may stick with the high rollers. Seems to be what most are going with. I think the Hope hubs are hard to beat...
I was offered a set of XT wh-m776 for a good price, has anyone any experience with them? Also OnOne max? Or am I just wasting my time comparing?
XT ones are surprisingly heavy, IIRC
Hope are also very easy to convert to different axles.
Tyres wise I run highroller up front, advatage rear for most of the winter. Minion up front for dryer conditions.
Thanks for the advice everyone.
Do the flow/hope hoops come sealed and ready for UST? Seems some do and some don't?
In general no - although some places advertise them as coming with the tubeless kits as part of a bundle.
The Sun Ringle Charger Expert on CRC for £175 are a bargain. Only about 1800g so pretty light for a 28mm rim wheelset.
Pretty much the same rim as a Flow - same width but have eyelets fitted - they use Stans NoTubes tubeless system and come with valves, yellow tape and sealant.
Pro2s with flows here, running tubeless with the yellow strip and sealant, nevegal front and ignitor ust rear. Awesome wheels!
