Cove Stiffee headse...
[Closed] Cove Stiffee headset question
[#6919341]
Hi all
Recently got a 2006 stiffee frame and need to check it can take an FSA Orbit MX 1 1/8 inch headset?
Can anyone help me please?
I haven't got access to the frame, so haven't measured it.
Thanks very much......
Posted : 09/03/2015 2:37 pm
Bump....Anyone?
Posted : 09/03/2015 3:13 pm
I have a 2012 Stiffee and that is the exact headset i have in mine, i would have thought it would be the same for the 2006 model.
Posted : 09/03/2015 3:33 pm
Thanks for the reply, I guess its NOT a tapered headtube and just straight?
Cheers Gnusmas
Posted : 09/03/2015 3:49 pm
Nope, not tapered.
I have a set of old pikes 1 1/8" steerer on it set at 140mm. Tried 150mm Sektors but preferred the 140mm set up.
Posted : 09/03/2015 3:51 pm
Great - thanks very much
Posted : 09/03/2015 3:57 pm
No problem, if you need any more info (if i can help) my email is in my profile.
Posted : 09/03/2015 4:04 pm
def not tapered. mine had (has!) an FSA pig DH pro headset in it, 1 1/8th.
Posted : 09/03/2015 5:33 pm
Just to add to the valid contributions....my 2009 Stiffee had a standard FSA like that at one point, and now a CK, so yes, I'm quite sure a 2006 version will also take any 1-1/8" 'normal' threadless headset, i.e. with the bearing cups outside the headtube.
One of the great things about the Stiffee is that the headtube is machined out at top and bottom for a really precise finish. The headtube is about 3 times thicker than most other bikes, so Cove can afford to do that 😉
And yes, 140mm or 150mm forks will be perfect.
Posted : 09/03/2015 5:56 pm
Thanks again everyone. Had a HJob in the past, but now ride a Yeti as I'm getting old. Always wanted a Stiffee for play bike, so lookny forward to the build!
Posted : 09/03/2015 8:12 pm
