I have a Cove G Spot and have been running it with a 150 mm Rock Shox Sektor solo air fork with an adapter to take the 1.5 down to 1 1/8 and then a FSA Orbit MX heatset. This gives an external bottom cup adding additional height of around 10 mm over an integrated set up. meaning, theoretically I have the height of a 160 mm fork without the travel.
I am now upgrading the fork to a Fox Float 36 (160 mm) with tapered steerer. Can anyone comment on what headsets they are using and whether these are external or integrated?
Many thanks.
Come on, a post asking an opinion and no one on Singletrack has one?
Have I slipped into a really unlikely parallel universe?
If you look on the cove website, the pictures of the G-Spot have it set up with an external lower cup and 160mm forks.
Anyway I don't think you can fit an internal/integrated lower cup on this frame with tapered forks, only with 1 1/8 ones as there isn't enough space.
Doug of basque mtb/food tours has a Gspot - pretty sure he runs a CK headset.
Aye, it's a ck, 1.5 down to an eighth reducer. External. Not had to touch it once in three pretty full on years. Come to think of it it's one of the few original things on that frame.
I'm running a hope 1:5 to 1 1:8 set in my 2010 gspot. Lower cup is pretty much internal. It's tricky to get forks seated but seems solid once tightened up.
Running hope pick n mix on my gspot with tapered forks external lower as that is all that will work with tapered forks. Can definitely recommend it. 2 years old now, been on two bikes and still going strong.
