Just ordered a new soul, my old one has a 68mm shell, the new one has 73mm. I'm using a shimano hollowtech 1 drivetrain, 113mm was spot on before, will 113mm do the new frame as well?
Cheers.
Posted : 27/01/2010 7:19 pm
Cut and paste from the email I've just sent you:
"Not sure to be honest. I redesigned the Soul for the wider chainline
of HTII about 3 years ago. Easiest way to check is to screw your old
BB into the shell on the driveside and install the driveside cranks.
If there's more than 3mm clearance to all the chainrings then you'll
be able to run a 73 x 113mm as it'll be 2.5mm closer to the frame. If
it's only just clear then you'll need to go to 118mm.
Hope that helps."
Posted : 28/01/2010 9:02 am
