Converting Dual Pos...
[Closed] Converting Dual Position Air to Solo Air
[#6998931]
Is it possible? The dual position lever on my 2011 revelations has decided that it no longer wants to move after not changing its position for a while. I've had it apart and cleaned it out but still no luck. As solo air is supposed to more supple i thought it could be a good upgrade.
Thanks
Posted : 14/04/2015 6:11 pm
 LoCo
The current (2013) onward soloair system has a different upper design with a air transfer port machined into the the inside of the stantion so that conversion won't work.
A coil conversion is possible, and feel good, however you'll get 145mm max travel out of them due to spring arrangement.
A dual air conversion is possible too for that model years.
Posted : 14/04/2015 8:55 pm
Thanks Loco, very much appreciated. I have actually sent you an email enquiring about prices for rebound assemblies etc. also. I might look into converting them to dual air also in this case.
Posted : 14/04/2015 10:00 pm
