If i want to space my set's of wheels out to run at 142mm for a new frame, is it just new axle caps/spacers? how do the disc calipers line up?
I mean, do frames with 142m rear spacing still use the same inboard caliper positions? or is there some kind of caliper spacer i'll need too?
I can imagine the drive side is just a mech end stop realignment, but disc side i'm not clear on.
They are all Pro2, or Pro2 evo hubs.
Any guidance much appreciated.
Lard.
Posted : 02/06/2014 7:53 pm
Same disc spacing, same everythink, just 3.5mm wider end caps that slot into 3.5mm recesses in the frame.
Posted : 02/06/2014 8:09 pm
Ah, so recesses eh! Thats the bit i was not seeing. Makes sense now.
Good stuff, thanks for the tip george.
lard
Posted : 02/06/2014 8:22 pm
