Confusion surroundi...
[Closed] Confusion surrounding 12x135mm rear axle
So i'm about to receive a hope pro evo 2 hub in the post and am planning sticking it on my new meta 5.5 frame I also have coming in the post, which takes either 135x10 or 135x12mm bolt-thru. I have ordered the 12mm bolt-thru hope conversion kit. My assumption is that I will also need an actual 12mmx135mm axle to go inside the hollow, er, axle? Is this correct or am I missing something? I can't seem to see them anywhere available online is the thing.
Thanks for any insights..
Posted : 30/05/2014 4:25 pm
Should be supplied with the frame.
Posted : 30/05/2014 5:23 pm
Meta frames don't usually come with a 12mm bolt unless you've specified it or the seller is supplying it.
The Hope conversion kit will allow the hub to take a 12mm axle (bolt through).
You'll also need the 12mm dropouts for the frame (both sides) and a 12mm bolt through axle or Maxle.
Posted : 30/05/2014 5:49 pm
Thanks folks. I've ordered the 10mm conversion kit and a dt swiss 10mm qr axle. Hoping it's all going to fit together! My belief is commencal will send both a 10mm and 12mm drop out but I'm not certain of this. Anyone any experience of this?
Posted : 31/05/2014 12:16 am
Well even if it only comes with QR dropouts you should be OK with your 10mm parts.
Posted : 31/05/2014 5:59 pm
