compressionless bra...
[Closed] compressionless brake cables?
[#8380536]
Im building up a road disc bike with TRP Spyre cable brakes.
what is the recommended compressionless brake cable?
thanks
Posted : 02/03/2017 9:36 pm
I'd go with the trp cable. I initially used jagwire but there was not enough outer provided to run continuous outer front and rear. Trp set has a bit more outer.
Posted : 02/03/2017 9:45 pm
I've had good results with the good ridge branded stuff off CRC, made a huge difference with my cable disc brakes on the commuter
Posted : 02/03/2017 9:58 pm
Linear Slic or Nokon if you are a fancy pants.
Posted : 02/03/2017 10:00 pm
 DrP
I've had yokozuna previously - very good, but really stiff!
Currently got jagwire road xl, running full length cable on internal routing.
Seems equally good..
DrP
Posted : 02/03/2017 10:04 pm
Nokon doesn't age well
Posted : 02/03/2017 10:07 pm
Yokozuna is good but goes rusty under the clear coat which pissed me off considering the expense so i fitted jagwire which is equally as good and far more flexible.
Posted : 02/03/2017 10:08 pm
On, and file the ends flat before fitting good quality metal ferrules.
Posted : 02/03/2017 10:32 pm
If you go for jagwire then look for the XL version as the normal road kit doesn't have enough outer for full length.
I have it on the winter bike and it's holding up well.
Posted : 02/03/2017 10:39 pm
Filing the ends flat actually makes the ends crooked when fitted, due to the strands of cable on the inside and outside of any curves bending by different amounts.
Posted : 02/03/2017 10:51 pm
Omg...this is so complicated
Posted : 02/03/2017 11:17 pm
Make your own - use alloy tubing for all the fixed runs of cable. I get mine from B&Q - dirt cheap. Make you own cable joints by getting the next size up and cutting a short section.
For a liner get some small bore teflon airline from an industrial parts supplier.
I did this one 6 years ago and it's still perfect.
[url= https://c1.staticflickr.com/3/2761/5815154075_7806059efc_b.jp g" target="_blank">https://c1.staticflickr.com/3/2761/5815154075_7806059efc_b.jp g"/> [/img][/url]
Posted : 02/03/2017 11:37 pm
Wow that looks ace
Posted : 03/03/2017 12:19 pm
That is exceptionally tidy. I've just this minute had a set of trp compressionless cables delivered. I may now take a trip to B&Q. What did you use for the non-fixed runs?
Posted : 03/03/2017 12:26 pm
I toyed with doing that, certainly for the bit that goes down the down tube. Didn't Avid used to sell a kit that was basically the same thing?
Avid full metal jackets but the kit only included two runs of solid tubing for the top tube and rear stays which you had to join with flexi cable.
Posted : 03/03/2017 12:28 pm
I found a nice length of stainless steel tubing in a model shop and used that for the seat stay section on my Cotic X.
Posted : 03/03/2017 12:43 pm
