Dont know if anyone can help but my specialzed command post isn't working right,
when i press the lever and press it goes down ,but when i press again it doesnt come up.
any ideas?
thanks
Low pressure in the air spring would be the first thing to check. Possibly needs a strip, clean and grease though.
Try putting some air in. Run ours at 25 psi. Theres not a lot can go wrong with them
Ok thanks ,will try some more air in tomorrow,if not I'll try and get it serviced
cheers
Mine was doing the same. Stripped, cleaned and a new cable and as good as new.
Does any one know what the reccomended psi is?
Thanks
25-40psi according to...
Cheers,i was worried,because i upped it to 40 from 18 psi,didnt want go over board.
said I'd never get one,but my mate bought me one as a thank you,and i couldn't manage without it now, only had it 3 months
thanks for replies
