Hi,
I've got a 2014 55 CR fork. I've reduced the travel from 160 to 150 using the supplied 10mm spacer. However, I'd like to get it down to 130mm so I can use them on my hardtail. Does anyone know if you can combine multiple spacers? Even if you can, will it still perform properly?
THanks!
Posted : 25/11/2016 2:39 pm
Windwave have confirmed it's possible (thumbs up to windwave for a very quick response), but they don't recommend it because it will sacrifice performance a lot because it's not designed to work that low.
Posted : 26/11/2016 8:54 am
