Cold setting road f...
[Closed] Cold setting road frame - 120mm - 130mm
[#8147998]
Should I try this myself? Anybody else done so? Got an old frame for my Mrs to use and want to run 10 speed campag!
Can anybody reccomend a frame builder that can do this?
Posted : 06/11/2016 2:27 pm
Have cold-set frames previously - you do need to go well beyond 130mm in order to get the required setting. Also might want to re-align the drop-outs as they'll no longer be parallel.
Posted : 06/11/2016 2:34 pm
you need not just to put a single bend in the stays - it will need at least two. I have done this but you need to be very careful. IIRC sheldon brown has usefull info on doing it
Posted : 06/11/2016 2:46 pm
It's dead easy IMO/E.
Just take it gently, pull the dropots apart. An adj spanner can straighten the dropouts.
Posted : 06/11/2016 3:28 pm
http://www.sheldonbrown.com/frame-spacing.html
Is a useful guide. I thought about it for a 126mm road fram so I could get a 130mm wheel in there. In the end I just shoved the wheel in as it was easy enough to do. 100miles on the bike now in that setup and it has been faultless. 10mm might be a bit tricky. If you have a spare wheel see how hard it is to get in and out. I know there are other complications but if it goes in it might just work.
Posted : 06/11/2016 4:14 pm
Only issue with just spreading a 120mm frame, is I guess it's a singlespeed? In which case it might be hard to keep the axle from moving if the dropouts aren't parallel.
Posted : 06/11/2016 5:11 pm
Issue I've seen tends to be that chainstay bridges can dislike it and crack.
Posted : 06/11/2016 5:36 pm
I do it all the time - there's a special tool I use for it, but you can do it by just putting the frame on the floor and pulling carefully. The dropouts will need to be realigned.
Posted : 06/11/2016 5:48 pm
