CNC/Machine Shops
[Closed] CNC/Machine Shops
 eoin
I've got a few small items drawn up that I need machining, nothing too complex but one has a couple of hex key slots in it which seems to be a problem for the local workshops.
So I need somewhere that can deal with a small order of some fairly small parts! Does anyone have any recommendations?
Thanks
Posted : 28/07/2011 8:59 pm
These are a couple I use round this way
http://www.km-engineering.co.uk/
http://www.cityengineering.com/
And this chap is often worth speaking to if you need something slightly unusual
http://www.lminteractive.co.uk/
Posted : 28/07/2011 9:13 pm
Marbridge in Tamworth are good.
Hex slots ? They would probably need broaching, so you'll likely have to pay for a tool.
Posted : 28/07/2011 10:26 pm
eoin - we at BETD may be able to help. Call Rob Lewis Tuesday and see what he says. Not promising anything ok.
Posted : 28/07/2011 10:27 pm
Blane precision engineering in Killern are very good
Blane Precision Engineering
Killearn
Glasgow
G63 9QG
Tel: +44 (0)1360 550492
Posted : 28/07/2011 10:29 pm
Also does it [i]need[/i] hex key slots? A flat slot for a screwdriver is an awful lot easier to make especially if you are prototyping
Posted : 28/07/2011 10:50 pm
was going to say not many engineering firms want to broach these days but if you look up cnc with rotary broaching you will find a hole host of companies who will do it on a cnc for you expect to pay by the hour
forgot to add some companies will dril the hex corners then clear the centre with a larger drill and mill the hex walls in
