Clicking when under...
[Closed] Clicking when under pressure.
Hi. Ive been on the single speed for most the winter and got my T-130 out yesterday and still have an annoying click/tick when i press hard on the right hand pedal. It does the same when off the bike when i hold the rear brake on and press on the right pedal (rarely does it from the left). It clicks when i press down then clicks again when i release.
My LBS said it was the rear linkage and stripped/cleaned/greased/re tightened and this helped for a few rides. I did the same process last year and it helped for one 30 mile ride. I i undo the rear Maxle the noise is the same. If i press on the crank arm and not the pedal the noise is also the same. It has a new Hope BB and i thoroughly cleaned and greased when that was installed.
So i can rule out the following:
Rear Maxle
Pedals
BB
Any ideas what i can try next?
Posted : 06/04/2016 2:10 pm
 D0NK
check the tubes and wields on the frame for cracks, especially seat tube, but yeah tricky with FSers so many things to develop play.
cranks might be worth a look.
Bolt on dropouts?
Shock bushes?
(cleaning and re-greasing BB doesn't seem very exhaustive testing, do you have/can you borrow a BB and cranks from elsewhere for testing?)
Posted : 06/04/2016 2:23 pm
Thanks. I have some XT Cranks and BB on my old bike i could try for a ride.
Posted : 06/04/2016 4:05 pm
Remove, clean and/or replace the headset and bars.
Posted : 06/04/2016 4:07 pm
Chainring bolts
Posted : 06/04/2016 4:12 pm
Are you riding clipped in? I had this with my road bike and it was the cleat that was clicking, sent me mad stripping the bike to try and sort it...
Posted : 06/04/2016 4:21 pm
I think I've solved it!!!
I took the cranks off to check the chainring bolts and spider and when i loosened the 3 spider bolts it made the same click. I put the cranks back on with the spider a little loose and i can't get it to click.
I had previously greased the spider and bolts but obviously that didn't work. Should i try something different other than normal bike grease?
Posted : 06/04/2016 4:28 pm
Spent ages trying to figure out what the creak/click was on my Orange. After stripping the components and regreasing everything it turned out to be the bearings, same with the GF's Transition. Check those.
Posted : 06/04/2016 5:46 pm
