Yes come on Si, get the geometry up here
Wheel base and BB height are variable depending on how the drop outs and shock plates are used/adjusted.
Small
570mm effective TT
390 ST
72.5 ST HA
67 HA with Fox 36
Medium
590mm effective TT
440 ST
72.5 ST HA
67 HA with Fox 36
Large
615mm effective TT
490 ST
72.5 ST HA
67 HA with Fox 36
34.9 Front Mech
31.6 Seat tube
New Tapered headtube Zerostack from 1 1/8” to 1.5”,
compatible with angle adjust headsets.
•ISCG05 Mounts, compatible with Hammerschmidt and most
chainguides.
•ARD – adjustable, replaceable, dropouts for adjusting wheelbase,
chainstay length, and different axle types to come.
•Custom, hydroformed tubeset for maximum strength with weight
savings.
•Travel: 6”
•Oversized main cartridge bearing pivots and lower link pivots
•High-end frame anodized bead-blasted finish with immaculate welding
and frame alignment 🙂
Any chance of a decent picture of the drop-outs?
Only image of the dropout i have is the one on the previous page. I'll see if i can get a close up shot.
EVO G2 built up, more images if you want them.
[url= http://farm5.static.flickr.com/4059/5120894273_ce5608c5be.jp g" target="_blank">http://farm5.static.flickr.com/4059/5120894273_ce5608c5be.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/93388219@N00/5120894273/ ]P1000318[/url] by [url= http://www.flickr.com/people/93388219@N00/ ]srbwilson[/url], on Flickr
great riding bikes .
shame my dealer's dropped them 🙁
There are no Chumba dealers, now only available direct through myself. If there were Chumba dealers the frames would be at least £400 more, just like a Cove/Intense for example 🙂
I can now confirm the EVO G2 will be available as a full build, with the below spec for a bargain (considering spec) £2699
CHUMBA EVO G2 Frame w/ RP23
Fox Float RL FIT
Thomson 70mm/31.6mm
Thomson 410mm/31.6mm
Crankbrothers Cobalt 15mm wheels
Sunline V2 710mm bar
Avid Elixr (set)
SRAMx.9 2x10 (shifter)
SRAMx.9 2x10 (rear der)
SRAMx.9 2x10 (crankset)
SRAMx.9 2x10 (front der)
SRAM PG 1070 Cassette 10 spd
SRAM PG 10SPd Chain
Schwalbe UST Big Betty (set)
CHUMBA Zulu Grips
CHUMBA Zulu Saddle
FSA Tapered Headset
