Chris King ISO Disc...
[Closed] Chris King ISO Disc rear hub question
[#2672398]
Got a good price for a 135mm [u]old[/u] ISO disc rear hub (gather that's a standard QR?)
Frame takes 135x10mm.
Will hub fit or will I have to shell out for CK's more expensive 135x10mm hub
Posted : 18/04/2011 1:25 pm
Not sure but fancy expanding on where the price is good - I'm after a rear CK ISO
Posted : 18/04/2011 1:37 pm
CRC's private sale has the old style 32h in black only for £233.
was 4 in stock half an hour ago.
Got some MTX 31 rims for £19 each too.
Hard to beat at that price!
Posted : 18/04/2011 1:46 pm
damn - I need a red one - thanks for replying tho steve
Posted : 18/04/2011 1:50 pm
You could either change the axle which is straightforward and will cost you about £65 if I remember correctly, or you can use fun bolts ehich are about £30. You can remove the qr inserts to put the fun bolts in.
Posted : 18/04/2011 2:19 pm
Cheers ash,
will have a hunt around for some fun bolts,
quick google turns up Bromley bikes does them.
Posted : 18/04/2011 6:42 pm
