Cheapest shock moun...
[Closed] Cheapest shock mounts?
Trying to sort out a mates NRS, we have a Rockshocks Ario and I was hoping to transfer the moutns off thew old NRS SID shock but they are two narrow to fit in the rockshox eyelets. (which is irritating as SID is a rockshox product, albeit 10 odd years adrift)
Trying to do this as cheap as possible, TF tuned is £30 quid a pair, I cant find any cheaper, does anyone know of a cheaper source?
Posted : 22/01/2012 5:06 pm
Be careful with the NRS- to make it work it requires a shock with no negative air in it. If the Ario you have has a positive and negative air chamber with seperate valves then it's fine, just put no air in it, if it's only got a single air valve it won't work because the NRS depends on their being no sag.
Posted : 22/01/2012 5:09 pm
Cheers munrobiker, we know this. Beggars cant be choosers, it will just bob a bit like non NRS frames, and the ario has a lock out...
Posted : 22/01/2012 5:11 pm
Simon, thanks for finding and posting that, I appreciate your effort but unfortunately its the same price as TF tuned.
Posted : 22/01/2012 7:12 pm
Sorry, thought you meant £30 per end. 😳
Posted : 22/01/2012 7:25 pm
