I'm after some relatively cheap lights for a spot of night riding. Nothing fancy or super expensive required. TBH I don't know where to start so thought best to come to the collective mind for advice, cheers.
Mtb batteries Lumentor.
C and B seen
Cheers for the suggestions. The c and b seen 1000 lumen light looks pretty much identical to the ebay cheapo that I got a year or so ago. The beam looks overly focused on one point and not an even spread.
Mapdec.com have some good cheap lights. I bought the thumb 1 for my lid and it's ace.
C and B seen here.......
Then for a better light spread add this diffuser.........
http://www.evomtb.co.uk/cb-seen-wide-anglediffuser-lens-for-10001200-lumen-bike-lights
And if you want to get really posh add a quick release mount instead of those horrid rubber bands 😉
http://www.evomtb.co.uk/cb-seen-handlebar-mount-for-1000-lumen-1200-lumen-bike-lights
[url= http://singletrackworld.com/forum/topic/that-time-of-year-is-coming-again-whats-hot-in-the-lighting-world?replies=381 ]alternatively, read the thread that's running on this very forum[/url]
+1 for Mtb batteries got one of the old ones and the lumen 800 both been very good light..
To be fair it's easier to just ask than it is to navigate or search on this forum. A wealth of useful info and helpful people STW may be, but user friendly it is not.
Oops - just remembered that I've come to work and left my Chinese lights on charge.
Got a charger from C & B seen to replace the nasty Chinese one that failed. Was a little suprised to see that it looked the same as the nasty one when it arrived.
The text on their site reads "C&B Seen is a UK based distributor of own-brand high-tech cycling, diving and utility lights..."
So maybe it was the same as the nasty one after all. Whatever, it works and my house has not exploded.
Those C&B seen lights look like rebranded Chinese £15 a pop-explodie batteries lights.
I wonder if there is any genuine difference (better chargers?) or if they are straight rebrands.
I went for the more expensive one, which isn't the same, and appears to be better.
http://www.candb-seen.co.uk/bikehead-lights/cabs-02-series---cree-xml.html
No particular reason why the charger and battery should be the same just because the head unit is though - I'm certainly not the only person to use one without any issues.
What's your budget?
Those moon lights from merlin look good for £100.
I've got a magicshine head unit for £40ish and a decent battery pack from MTB batteries for £37.
Does the job fine.
Considering what I used to use when first night riding, a Smart Halogen 12w single lamp, I'm surprised I didn't crash and die.
Look on the big light thread, quite a few good options for under £100.
Has anyone got the C&B Seen all in one light.. the city slicker I think?
Looks a deal for £80 if the light is usable.
that won't explode or burn my house down
You've always got that risk with any lithium battery, even the expensive ones. Just it's a much lower risk compared with cheap.
The important bit is the battery. Doesn't matter much about the light (if you're ignoring quality, functionality, easy of use & fitting, performance, durability, warranty etc), but the battery and charger needs to have protection circuits in there to cope with the common problems and prevent a run away, and be of decent quality and build such that they're not dangerously assembled, comply with safety regulations in the UK (and don't believe a CE logo from China), and aren't made from recycled laptop batteries that at the very least will only last a couple of months.
any old cree torch and bike mount, then decent batteries and charger from someone like torchy the battery boy, or something from MTBbatteries for a complete system
