Changing stems
[Closed] Changing stems
Would I notice changing from a 6 deg stem to a 0 deg rise stem?
Posted : 19/10/2009 11:18 am
Only if it was 300mm long. ๐Ÿ™‚
Nah.
Posted : 19/10/2009 11:21 am
Posted : 19/10/2009 11:24 am
turn it over and get a 12 degree then put a 5mm collar in then prob will be about the same and then you can compare?
Edit: duh or even just take a 5mm collar out and would give you the same effect I would think? ๐Ÿ˜ณ
Sorry, should have said: It's for a 70mm stem.
Posted : 19/10/2009 11:29 am
you wouldnt really notice it IMHO -
Posted : 19/10/2009 11:31 am
Probably drop you bars by about 7 - 7.5mm (if my maths is correct). Depends if that's what you want - it might feel a bit different but probably not.
Posted : 19/10/2009 12:04 pm
Yeah it's about 7mm (I worked it out in AutoCAD). I have just remembered that I took the spacers out that were below the stem so if I find it too low, I can always put them back in.
Posted : 19/10/2009 12:20 pm
I'd say maybe... in terms of handling prob not, but...
On my full susser, if I remove one 10mm spacer from the bottom and put it on top of the stem, I get the most god awful backache after about 2 hours which doesn't materialise with the spacer back in place.
Posted : 19/10/2009 12:29 pm
