I've got a bike with boost wheels/fork. I have a old saint chainset I want to put on there.
Is it compatible or do i have to get a 'boost' chainset?
Posted : 14/05/2018 10:57 am
It depends on the frame.
Posted : 14/05/2018 11:03 am
It just means the chainring will be 3mm closer to the centre of the frame than it should be - that might mean the chainring touching the chainstay if clearance is tight. If that works, then it means a less-than perfect chainline, although that can be kind of a good thing with some 1x11/12 setups
I'd give it a try, might be OK
Posted : 14/05/2018 11:17 am
Cool - I'll have a go then.
Posted : 14/05/2018 3:28 pm
I was wondering about this, could you not space the chainring out with some 3mm spacers and longer steel chainring bolts.
Posted : 14/05/2018 3:55 pm
You couldn't space it. You could put the ring in the outer position - that offsets it too much though.
Posted : 14/05/2018 4:31 pm
