Chainset advice if ...
[Closed] Chainset advice if you please...
I have an XT M760 chainset with nearly new middleburn chainrings on it. However, the axle on the chainset is borked so I need a new chainset. If I buy an XT M770 9speed chainset, will my middleburn chainrings stil fit it for use when the new chainrings wear out?
I guess what I am asking is do the old and newer XT chainsets all take the same BCD chainrings.
Alternatively, any recommendations for a decent new chainset?
Thanks in advance,
STS.
Posted : 03/02/2012 8:14 am
 Bazz
Yes i believe they do have the same BCD, could look at SLX for a new chainset, only 40g heavier iirc and a fair bit cheaper. To be honest i see know reason to buy chainsets from anyone else other than Shimano.
Posted : 03/02/2012 8:45 am
I'd second the SLX. I've just bought one, it's strong and cheap and it only weights a shart more than XT. I think it looks nice too.
AFAIK they're all the same BCD.
I've gone through a set of XT, XTR and Saints in the last 3 years. The SLX is cheap so if it needs replaced them I won't worry so much.
Posted : 03/02/2012 8:56 am
I had thought about SLX - I just want to make sure that my old chainrings can be used at a later stage as the middleburns last for a lot longer than shimanos in my experience. I guess SLX is cheap enough to replace the lot each time mind you.
To be honest, I find most cranks fairly horrid to look at - they're all a bit poncy looking and have too much branding all over. Shimano are the simplest looking IMHO so I was going to stick with them...
Posted : 03/02/2012 9:04 am
You could always polish them out if it bothers you! I swapped my chainrings over from old XT to the last version of SLX, no problems. It'd be worth checking the BCD but I'm sure it's OK.
Posted : 03/02/2012 9:09 am
