Chainring advice pl...
[Closed] Chainring advice please for numpty
[#1788767]
To cut a long story short I run a Truvativ 24, 36 & 48T chainring combo on my HT as it doubles up as my commuter. I wanted my LBS to fit new middle & outer chainrings which was agreed with the mechanic, however after dropping the bike off the next day the LBS rang later on (another mechanic not the one I dealt with earlier) to say that for £10 more I could have a Shimano Deore chainset including BB fitted.
I said I run 24, 36 & 48 & if they did the same combination then to fit it, they said Yes they had that combination. After picking the bike up & getting home I checked & found that although the other chainrings were 36 & 48 the inner was a 26T 😕
I am going to speak to my LBS tomorrow to try to resolve this but I was wondering whether the Truvativ 24T chainring which is in excellent condition would fit on to the Shimano chainset?
Any help would be appreciated.
Posted : 11/07/2010 1:07 pm
If it's got the same number of bolt holes at the same diameter, then there should* be no problem
But do you really think you'll notice the difference between 24/32, (guessing a bit on the rear gear there) and 26/32?
*I'm not promising that though!
Posted : 11/07/2010 1:11 pm
Thanks tthew.
It does have the same 4 bolt holes so I think that it might actually fit. I'll speak to the LBS about it.
I'm a wimp & run a 34T rear cassette, that being said it is noticeable when I ride my other bike with a 22T inner ring that the hills are much easier, a 26T inner could be even harder on the hills.
Posted : 11/07/2010 1:20 pm
