chain suck
[Closed] chain suck
[#1542823]
Hi, I'm sure this topic has been brought up before.
is there any bike tweeks that can be made to minimize chain suck on the triple chainset?
Posted : 25/04/2010 2:57 pm
Clean and lubed chain? replace worn transmission. I found when i get it that exaggerating pedalling "smooth circles" helps.
What frame are you riding?
Posted : 25/04/2010 3:09 pm
your right about smooth circles, i get it when i'm not pedaling on techy descents, then when i need to pedal i'll get a hang-up whilst the chain sorts itself out, maybe that the chain is too slack you know what i mean? chain and rings should be fine, the frames is a carbon focus
Posted : 25/04/2010 3:15 pm
 nuke
[i]Clean and lubed chain? replace worn transmission.[/i]
+ 1
I found when I switched to Deore steel rings, the amount of times I got chainsuck decreased. I have a few zipties with a bit of inner tube on the chainstay to protect it.
Really only time I've had it recently was on a technical climb in the mud.
Posted : 25/04/2010 3:17 pm
I got it a couple of times on my Inbred when I first built it up, but a ziptie just behind the chainrings seems to have cured it completely. Plus the regular lubing and cleaning above.
Posted : 25/04/2010 3:18 pm
cheers guys, i'll give my chain some more loving.
Posted : 25/04/2010 3:43 pm
