Chain jumping, help...
[Closed] Chain jumping, help/advice please
[#4873349]
Hi all,
I recently had issues with the chain jumping off the front chainring (big ring on my SLX M665 double). I replaced the chainring as it was pretty worn, however the problem is still there - though not as bad. The chain itself is 2 years old - XTR - and the cassette not quite a year old. I'm trying to rule out other issues before I buy a nice chain. Could it be something else?
Col
Posted : 15/02/2013 11:45 am
measure the chain for wear.
chances are if the ring was knackered then the chain is too.
Posted : 15/02/2013 11:48 am
Depending on use thats a very old chain .I would replace the chain and cassette before you wear out your new chainring as well .
Use wise, 2-3 week on average through-out the year at an average of about 10 miles per cycle.
Thanks for the advice.
Posted : 15/02/2013 11:51 am
you're gonna have to buy a new cassette and chain at some point in the future anyway, buy them and stick em on and if it still jumps you can rule that out, chances are it won't. 2 years on one chain is long time if you use it twice a week.
Posted : 15/02/2013 11:58 am
I had the same prob once,turned out to be a slight bend on the crank arm,where the chain ring bolts on.Maybe worth spining the crank slowly and see if theres a buckle.
Posted : 15/02/2013 6:40 pm
