I have some engineers at work. They have a degreasing bath tank type thing. My chain is dirty.
Will sticking my chain in the degreasing bath tank type thing be good or bad for it?
perfect, I use ours all the time
cool, i wondered whether it might be a bit too strong, sure i read something somewhere about stripping out the oil/grease from deep inside...
it will do that for sure but its simple enough to relube, I usually do it towards the summer when dry lubes start to make sense
and ideally your engineers will have an air line to dry it out 😉
I have a tank in my shed purely for chains and drive train parts. I use Deb Jizer degreaser and it works a treat. You should wash the de greaser off thoroughly with hot water and then dry the parts before applying fresh lube
I pay for enough compressors so I hope so!
