Chain dropping
[Closed] Chain dropping
Got the narrow/wide and got the clutch mech but dropping my chain for fun on techy stuff.
I have no ISCG tabs, and no spacers on my BB - any ideas?
Posted : 03/05/2014 6:58 pm
remove some more links from the chain? Or look at the chain line. If you cannot space the BB, what about moving the chainring to the outside/inside of the chainring arms to get a better line?
Are you on full sus or hardtail out of interset?
Posted : 03/05/2014 8:10 pm
Add a bash ring.
Posted : 03/05/2014 8:23 pm
Put a guide on? Superstar and a couple of others do seat tube mounted guides.
Posted : 03/05/2014 9:00 pm
What chainring are you using? I dropped my chain a couple times going through compressions with a Works Component ring.
Posted : 04/05/2014 8:44 am
How old is your chain? I find the rings are quite dependent on the chain not being overly worn.
Posted : 04/05/2014 10:14 am
Already got a bash, drops inside. It's a race face narrow wide 32T. Seattube isn't cylindrical so can't fit one of them seat tube mounted guides.
Chain is knocking on a bit tho tbf. Maybe try a new one.
Posted : 04/05/2014 11:15 am
Make sure there's as little chain as possible, and check the tension on the clutch mech as it is adjustable.
Posted : 04/05/2014 1:27 pm
This is based on a road bike, however Rotor do a chain catcher which mounts to the front derailleur mount then you bolt the FD on, can't see why it wouldn't work on a MTB.
Posted : 04/05/2014 3:39 pm
Would have to lose the bash ring but this might be just do it - can't get my head round the effing price tho!?
http://www.tweekscycles.com/Product.do?method=view&n=3511&g=268370&p=268372&c=215&utm_source=Google&utm_medium=Base&utm_campaign=Chain%20Guides&gclid=CPaRgKXkkr4CFSoTwwodBCIA1w
Posted : 04/05/2014 5:25 pm
