Hi all
I've just bought a 2007 Specialized Enduro S-Works frame and a Superstar Components ISCG/BB mount double chain device, however when fitted this touches the chain stay.
Also the chain doesnt sit properly in the roller as it seems to far across - I dont want to cut it and bend it to fit - I'd rather have a chain device that fits properly, so I'm going to send it back.
Does anyone have any experience of this frame and chain device combo? Or know of a chain device that will definitely fit?
Thanks,
Chris
Try rotating it anti-clockwise more. Which part of it is touching the chainstay?
Its already rotated as far as it'll go 🙁
It's this one http://superstar.tibolts.co.uk/product_info.php?cPath=56&products_id=336
The bit that touches is behind the roller where it lips up? But like I say I dont really want to cut it
As above roate ACW.
I have an SX trail 2007 - when running double & bash used a Blackspire stinger - no problems with fit and it looks the same as the superstar device.
The stinger was the OE fit by Specialized at the time.
ISCG or BB mount?
Ah stuff what I said - the frame is different. Looks like you have a BB mount so rotation is unlimited ?
steel4real - my frame is this one? http://www.specialized.com/us/en/bc/SBCBkModel.jsp?spid=22224&menuItemId=0&gold_ses=
Same as yours or not?
Yes - that is the same as mine !
When I put 2007 S works enduro into Google I got the one with twin crown forks ?
Any road, in the picture of the link you gave, you can see the chain device. I'm sure the OE was a Blackspire Stinger, that's what I used and it mounted fine on the ISCG mounts in the right position without being rotated all the way one way. It was spaced out with one M6 washer.
If you're wondering how I'm so sure, it's because I've just taken it off to go single ring & chain device.
I had to dremel my SS single chainring one to get it to fit a hardtail. there is a hell of a lot of excess metal in it.
If you rotate it too much it just wont work and rub like hell
steel4real - Yeah not sure what's going on with that - must be different types of s-works?
Anyhoo - does that mean you're selling your chain device...?
Tim - yeah we rotated it and it jammed the chain. Like I say it also missed the roller by miles so I dont want to have to cut drremmel or bend it if i can get a one that fits properly 🙂
Don't mind you asking - but no, I'm undecided if I'll stick to single ring.
CRC have them:-
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=17282 ]Stinger[/url]
Also available in a range of colours.
([url= http://www.specialized.com/us/en/bc/SBCBkModel.jsp?spid=22007&menuItemId=0 ]Mistaken Enduro ![/url])
Cool - well thanks for your help!
If you enlarge the pictures on here you can see the device - should also be in the spec with chainset spec ?
[url= http://www.specialized.com/us/en/bc/SBCProduct.jsp?arc=2007&sid=07Enduro_SX ]Enduro SX trail 2007[/url]
[url= http://www.specialized.com/us/en/bc/SBCProduct.jsp?arc=2007&spid=22012 ]Enduro pro[/url]
Ah so it is - blackspire stinger! Thanks again 🙂
