Picked up a dynamo hub with a centrelock mount, We use 203mm rotors on the tandem. Some of the adapters I've just seen online say "165mm max size" or even "160mm max size". Other make no mention of max size
Is the max size thing a "get-out" clause? Is the absence of such from certain listings an oversight? Should we just get a big centrelock rotor (only £10 plus postage from Merlin so way cheaper than I expected!) or will be ok with an adapter?
thinking in, TBH with the rotor from Merlin being so cheap, is there any reason NOT to just get that?!
Get the rotor, I might have a 210 max adaptor in the shed so will pm if I do..
Ah, sod it, just gonna get the rotor. Means it will be easy enough to have a spare wheel ready to go, too...
I have DT Swiss cl adapters with "max 210" on them.
I ordered the rotor - it was £9.49 plus postage for an adapter from Wiggle, or £10 plus postage for a rotor
