Centre Lock Shimano...
[Closed] Centre Lock Shimano Adaptor Help
[#6983142]
Running Zee steel discs on my Jekyll and have just got some nice floating discs. Rear is fine, as standard 6 bolt, but the front is the bolt through centre lock. You can fit a steel discs on the adaptor on the hub, but not a floating disc, although this slides off the splines when undone. Can anyone help on the adaptor I need ?. The lock ring on this hub needs a bottom bracket spanner rather than a cassette lock ring spanner. Wheel is a Shimano MT68. Same Hub lock ring as this:
http://www.chainreactioncycles.com/shimano-xt-front-disc-hub-m788/rp-prod67215#bazaarvoice_reviews_tab
Thanks
Posted : 07/04/2015 9:00 pm
I'm using the DT Swiss adapter on the back of my Trigger.
Posted : 07/04/2015 9:10 pm
Eddie, rear hub has the smaller lock ring on the 142mm hub unless you have a link to see if DT do a front hub adaptor?
Posted : 07/04/2015 9:23 pm
[url=] http://www.chainreactioncycles.com/mobile/dt-swiss-centre-lock-adaptor/rp-prod79799 [/url]
I think that's right.
Posted : 08/04/2015 1:54 pm
