Carbon steerer bung...
[Closed] Carbon steerer bung?
[#11049525]
Having got Mrs B some carbon forks for her mtb, i need a steerer bung in order to fit them.
Are they all the same? Any recommendations? Is it correct that the bung has to extend to the area the stem clamps?
Thanks
Ian
Posted : 14/02/2020 8:37 am
This is all you need they work very well
https://www.planetx.co.uk/i/q/FSPXFBUMK2/planet-x-carbon-steerer-fork-bung-mk-2
Posted : 14/02/2020 9:26 am
That one won't probably won't fit an mtb steerer.
Posted : 14/02/2020 9:28 am
it doesn't 'have to' but unless you are a weenie then it's a good idea to have a longer one, to offer some support.
I prefer the ones with springs around the wedge part. Gives more adjustability than a fixed central shim (like the one above). Something like this:
fbadf
https://www.ebay.co.uk/itm/New-Packaged-BBB-Powerhead-Road-Bike-Fork-Bung-Top-Cap-For-Carbon-Steerer-1-1/323684778529
Posted : 14/02/2020 9:30 am
That won't work either.
OP - you need one designed for MTB steerer's - they have a different internal diameter.
Posted : 14/02/2020 9:33 am
https://www.youtube.com/watch?v=NQJUSZeJE8A
Posted : 14/02/2020 9:41 am
I've used the Exotic bung with no problems.
https://www.carboncycles.cc/index.php?s=0&c=70&p=637
Posted : 14/02/2020 9:47 am
That won’t work either.
OP – you need one designed for MTB steerer’s – they have a different internal diameter.
Do they do MTB specific ones? Not obvious in the CRC listings.
This one is what I'd think would be right, and one of the reviewers says "Perfect for my MTB"
https://www.chainreactioncycles.com/bbb-powerhead-compressor-adjuster-bap03/rp-prod29884
I prefer the more knurled ones - one I had like the PX above kept coming loose (An FSA IIRC)
Posted : 14/02/2020 9:54 am
I don't think they do have a different internal diameter. It's just that Hope (and others) do a Head Doctor style plug that's designed for aluminium forks which have a slightly larger diameter. For carbon forks, you usually find that the steerer wall thickness is a little thicker than Aluminium, so the Head Doctor is a tight fit at best. But in Carbon, they should be the same and work the same. Certainly, I've used expanders like the above for both MTB, Road and Gravel carbon forks from 2007-2020.
Posted : 14/02/2020 10:10 am
From the P-X listing linked above;
Please choose the Silver fork bung for MTB forks
I couldn;t see one but several carbon bungs I've had have come with a spacer that you fit/don't fit (maybe that's for carbon or alu though.
I'm just aware that there is a difference, not quite sure what it is and don't want the OP buying the wrong thing and it going pear shaped.
Posted : 14/02/2020 10:22 am
Very helpful of Planet X to advise you choose something they don't have! 😆
Posted : 14/02/2020 10:32 am
Yes they do come in different diameters, find the spec for your fork, google "carbon fork stearer bung 2x.xmm" and buy whatever comes up.
I think mine's from brand-x.
You could probably get away with over tightening a smaller one, but I assumed the segments were profiled to fit a certain diameter, better it pushes out evenly than just having 4 points of contact.
Posted : 14/02/2020 11:04 am
Road or mtb an 1/8th fork(all are at steerer end) Apart from Giants overdrive 2. it’s same diameter bung.
Posted : 14/02/2020 11:09 am
Thanks all! Ordered from Exotic 🙂
Posted : 14/02/2020 11:45 am
the outer diameter is 1 1/8. Fine. But bungs go inside, not outside....
So ...carbon steerers have slightly smaller internal diameters than aluminium, as the wall thickness is greater. Hence why Hope bungs fit alu but not carbon.
Posted : 14/02/2020 9:16 pm
