Carbon Jeffsy, 29er...
[Closed] Carbon Jeffsy, 29er. Anyone running a boost oval 32T chain ring?
[#9862815]
Wondering about clearance to frame, boost chain ring by the way...
From the AB site and their measurements I think it should be ok but would like to check.
Anyone? 🙂
Posted : 26/02/2018 12:56 am
I have a Jeffsy 29er that came with the Eagle drivetrain and I've just gone from a 34T to a 32T 3mm offset (boost) with no issues.  Does that answer your question?  (If not I think I don't know what you mean 🙂 )
Posted : 26/02/2018 1:09 am
I think you did understand mate! Thanks.
Is your frame the carbon one as that has less clearance than the alloy?
Thanks again. 👍
Posted : 26/02/2018 1:45 am
Thanks again. 👍
Posted : 26/02/2018 1:46 am
The 2017 Jeffsy 29s came with boost adjusted spindle for the RF cranks, so they need a non-boost chainring. I've run a 32t and a 30t without clearance issues.
Posted : 26/02/2018 2:59 pm
Cheers mate.
I'm running a non boost crank as i bought the frame second-hand. However, allowing that I will just get a boost chain ring then I should be ok. Is yours an oval though, as that is nearer a 34 at max width?
Posted : 27/02/2018 2:56 am
Yep, both were oval. No clearance problems, I’d say it could run a 34t without issue.
Posted : 27/02/2018 7:51 am
Mine's carbon.  Came as stock with 3mm boost offset 34T round chainring and the Eagle X01 cranks.  Hope that helps.
Posted : 27/02/2018 9:59 am
Checks buddy, that does help!
Posted : 28/02/2018 11:44 pm
