Canyon Nerve Headse...
[Closed] Canyon Nerve Headset
[#8051825]
Hi,
I have a Canyon Nerve XC 2012, and my Acros Aix-03 Headset has finally given up. I've read some forums that suggest alternative headset components (Hope pick and mix for the top, Superstar components for the lower).
I've removed my old bearings easily enough, and was surprised to see they are traditional bearings rather than sealed looking cartridge bearings. They definitely don't look like the exploded diagrams of the headset I have found online. However, I'm left with silver components inside the Headtube at both ends, and I don't know if this is part of the frame, or whether this is the remains of the Acros headset. Maybe there was a cartridge bearing in there after all? Do I need to extract this before replacing with new? I don't want to take a screwdriver to it unnecessarily in case I damage the frame. I have pics on my phone to upload.
thanks
NBD
Posted : 12/09/2016 10:30 pm
[url= https://postimg.org/image/sfe4ecloj/ ]what's left in the top of headtube[/url]
Posted : 12/09/2016 10:33 pm
Hard to see from the photo put that looks like half a sealed bearing so they probably were sealed bearings before they disintegrated.
Also still looks like a seal is on top.
Should lever out with a screwdriver easily. Then you'll be left with the the race which you can drift out from the reverse, same goes for the other end. Alternatively for an easy life just replace the bearings.
Posted : 12/09/2016 10:56 pm
I replaced mine last year with:
HS2030 Cane Creek Bike Headset Bearing 30x41x6.5mm
http://www.bearingsrus.co.uk/hs2030
Type 2 - Headset Bearings 1.5" or Tapered 45x45 Degree x1
http://www.superstarcomponents.com/en/type-2-headset-bearings-1-5-or-tapered-45x45-degree-x1.htm
Yes they're sealed bearings you need to knock the remaining half of the cases out. Preferably carefully. I seem to recall making hard work of it, is as much as I can say, but isn't too difficult really.
Posted : 12/09/2016 11:56 pm
thanks for your help. Screwdriver carefully knocked out the remaining half of the lower bearing cartridge. Top looks a bit trickier as no overlap to use from the bottom...
Posted : 13/09/2016 10:22 pm
