Canyon going metal ...
[Closed] Canyon going metal again
[#8028554]
A bar mounted lever that can disconnect your drivetrain so that pedal feedback is turend off.
No, me neither.
http://www.mtb-mag.com/en/eurobike-canyons-project-disconnect/
Posted : 01/09/2016 9:50 am
Doesn't fully disconnect drive train though does it, still some resistance from chain I imagine? Is it serious?
Posted : 01/09/2016 10:27 am
*checks date*
Posted : 01/09/2016 10:29 am
ferrals - Member
Well, it means you're basically freewheeling so the suspension can't pull the chain.
Posted : 01/09/2016 10:45 am
I can just imagine the cornering technique video of the future now.
And press this button to drop your dropper post to about 2", then pres this one to disconnect the drive chain, then this one to shift down a couple of gears........
A short while later..........
Now put the post back upto pedaling height, and sprint!
AAAGHHEHHEEEE FLIBBERRRTTYYYYYFLIPPINGGIBBLETTTSSSSSSSSS my PLUMS!!!!!!!!!!!!!!!!!
Posted : 01/09/2016 11:15 am
 D0NK
quite, if it really does completely disconnect your drivechain I can see a few nads/stem interfaces
Posted : 01/09/2016 11:24 am
Aaah! MENTAL! I thought they were stopping carbon bikes from the title 😆
Jeez, first it was my wheel size causing me problems I didn't know I had, now it's "[i]It’s where the chain grows and literally tugs on the pedals[/i]"..
better be an early adopter before I embarrass my self with a u-turn like I did with 29ers!
It's LITERALLY! TUGGING! on my PEDALS! HELP!
Posted : 01/09/2016 11:37 am
Presumably it will eventually automatically disconnect when the rider stops pedalling? Electronic system, similar to the Lappiere EI suspension effort?
Posted : 01/09/2016 11:38 am
Could also help in those situations where you want to turn your pedals 180 degrees really quick between corners but can't because in too high gear.
With a bit of advancement it could become part of an electronic groupset and replace the freewheel, auto-disengage when back pressure on the chain and re-engage when pedals turn a full-rev, no need for buttons then, removes a source of friction so downhillers on and off road could go a little bit faster.
Posted : 02/09/2016 4:05 am
and Chris Porter is busy enjoying a celebratory something now somebody else agree's with him
Posted : 02/09/2016 4:18 am
I think it's a development from their pro road and CX bikes where the hidden motors used to make the riders pedal round corners.
Posted : 02/09/2016 7:38 am
A full turn would be more than enough to ensure your plumbs meet your stem. Would need to be near enough instant engagement - you might actually need every pedal stroke available in order to clear whatever's next
Posted : 02/09/2016 8:06 am
But it won't take out the clutch or mech spring tension which is what he's on about anyway. There will still be chain growth which will be resisted by the mech regardless. Bat poo mental
Posted : 02/09/2016 8:29 am
