Cantilever leftover...
[Closed] Cantilever leftovers
[#4340709]
How do,
My Kona Unit has canti mounts that short of grinding off, I'm at a loss as to how to disguise.
I have these plastic caps on them at the moment, but is there a more elegant solution?
Cheers folks.
Posted : 07/09/2012 3:21 pm
not really, get your hacksaw/file or grinder out.
Posted : 07/09/2012 3:26 pm
Can you unscrew the posts from the frame bosses? Could then put some blanking plugs over the top. Not perfect, but about as low-profile as it gets without the aforementioned hacksaw/file double-act.
Posted : 07/09/2012 3:29 pm
Hmmm, wasn't aware that they would unscrew?
I shall try with some rubber and a pair of mole-grips...
Posted : 07/09/2012 3:33 pm
Only alu frames have removeable posts IIRC, that is steel?
Posted : 07/09/2012 3:35 pm
I've seen mudguards that you can fit to canti bosses. I think Decathlon do one? Depends on how you feel about mudguards though. [Edit: [url= http://www.btwincycle.com/EN/mtb-rear-17140823/ ]here[/url], not sure if you can still buy them though.]
Old 456s have removable canti bosses.
Posted : 07/09/2012 3:36 pm
The posts should have flats ground into the them, near the frame bosses, so you can get an open ended spanner on them and unscrew them.
Posted : 07/09/2012 3:37 pm
Some steel posts are removable, most aren't. If there are flats on it then you can use an 8mm spanner.
Posted : 07/09/2012 3:39 pm
Difficult to see in the pics, but now tend to agree with al/Ben - they look like they are non-removable.... I stand corrected.
Posted : 07/09/2012 3:41 pm
Thanks for all the posts, turns out they're non-removable.
Shit it.
Might just use this as an excuse to strip and repaint the lot, getting rid of the rest of the unused cable tabs etc. Hmm...
Posted : 07/09/2012 4:01 pm
 robh
Presence of flats doesn't mean they are removable. Seen plenty welded on steel ones with flats but fixed posts.
I'd heat them with a plumbers blow torch and remove, will shag up the paint finish though.
Posted : 07/09/2012 5:00 pm
They'll be tig welded on, no?
Posted : 07/09/2012 7:24 pm
 robh
Come to think of it I've only done that to down tube shifter bosses on a road bike that were brazed on.
Posted : 07/09/2012 8:29 pm
I just ignore mine. Stick a break booster on to tighten up flex? Or get a respray. But to be honest, it may be cheaper to just buy a new frame
Posted : 07/09/2012 8:44 pm
