Canti to v brake ca...
[Closed] Canti to v brake cable clamp conversion.
[#412562]
I think I have 2 options
1) file out clamp to fit the top tube. It fits the 29.3mm downtube fine, but the 30.5mm top tube is too big. Crazy it's just over a mm difference.
or
2) find a clamp for the seatpost or seatpost clamp that does the same cable stop thing. Seatpost is 26.8mm.
or even use the noodle with a good canti and keep v up front. This might be better on the eye. Thoughts?
Posted : 22/03/2009 7:57 pm
full length housing is the other option. Fitted with some of those M part adhesive zip tie mounts.
Posted : 22/03/2009 8:09 pm
 taka
i did what onza said it works fine
Posted : 22/03/2009 8:10 pm
can't you open the clamp out a bit?
Posted : 22/03/2009 8:15 pm
Full length is a very good idea I had never thought of - obvious really when pointed out.
Posted : 22/03/2009 8:23 pm
