canti brake hanger ...
[Closed] canti brake hanger problem
[#2102473]
bit of a problem. i have some cantis to fit a pompino frame but the steerer is only long enough for the stem so cant fit a canti hanger on the steerer as normal
also the forks are only drilled at the rear so i cant bolt a fork mount one there either
so any solutions other than mini v's ?
thanks
Posted : 19/10/2010 12:14 pm
ignore me, i'm a fool.
Posted : 19/10/2010 12:17 pm
or this;
[url= http://www.ukbikestore.co.uk/product/14/bhidc/id-front-clamp-on-cable-hanger-fits-to-stem-or-steerer.html ]http://www.ukbikestore.co.uk/product/14/bhidc/id-front-clamp-on-cable-hanger-fits-to-stem-or-steerer.html[/url]
Posted : 19/10/2010 12:19 pm
i cant see how that would fit a stem ?
Posted : 19/10/2010 12:27 pm
imagine it so that the 'elbow' is pointing back towards the steerer and the bottom of the elbow is down towards the brakes with the cable exiting through there and down (i.e. cable routing is reverse of what it would be for the way it's photographed).
Posted : 19/10/2010 12:30 pm
Do any of [url= http://www.sjscycles.co.uk/cable-hangers-dept683_pg1/ ]these from SJS[/url] solve the rear, various seatbolt mounted hangers?
Does [url= http://www.edinburghbicycle.com/ebwPNLqrymode.a4p?f_ProductID=12447&f_SupersetQRY=C183&f_SortOrderID=1&f_bct=c003154c003141c003205 ]this from Edinburgh Co-Op[/url] work for the front?
Posted : 19/10/2010 12:32 pm
yeah but stems are all different shapes i could see it working on a bar perhaps but my bars are 26mm anyway ;-(
Posted : 19/10/2010 12:33 pm
sorry rear is sorted with a hanger but its the front im stuck with . mefty the front fork needs a hole in the front for those i think
Posted : 19/10/2010 12:36 pm
you can get stems that are drilled for canti brake cables.
Posted : 19/10/2010 12:37 pm
Mike Ive some 44cm OS Bell Laps if you want to resolve the bar diameter issue...
Posted : 19/10/2010 12:38 pm
yeah i think that may be the only option. that or swap forks over from the pompino to the crosscheck
Posted : 19/10/2010 12:39 pm
Drill the fork!
Posted : 19/10/2010 12:41 pm
i'll have a think nick thanks
i dont trust myself with a drill al im afraid and its on a curved surface too just to make it harder
Posted : 19/10/2010 12:45 pm
Sorry misread your post.
Posted : 19/10/2010 12:47 pm
come from the back!
other than finding a stem with a cable stop in (i can't find one quickly)
drilling the fork
getting a longer steerer
i'm not sure either...
Posted : 19/10/2010 12:52 pm
Drill the fork. Use a smaller drill bit, come in from the back and use the rear hold as a guide and then once you have a pilot hole, you can keep stepping up the bit size until you get what you need.
Posted : 19/10/2010 12:59 pm
what about one of those steerer extension things?
Posted : 19/10/2010 1:00 pm
mark with punch before drilling
Posted : 19/10/2010 1:12 pm
ive given up for now and put the crosscheck back to drops and the pomp to flat bars. i may swap back in the future but it will do for now.
i think i could probably go thru the back of the fork and buy a new hanger but i think i will just keep my eyes out for a used pomp fork with a longer steerer or even buy new later
thanks all
Posted : 19/10/2010 1:35 pm
only thing i can offer is to get a super-low stack headset which might give you space for a spacer hanger under the stem.
Posted : 19/10/2010 1:43 pm
